跳转到主内容
Disassembling Nokia 6236i Display
你所需要的
  1. Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Battery: 步骤 1 中的图像 1,2 Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Battery: 步骤 1 中的图像 2,2
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Disassembling Nokia 6236i Display: 步骤 2 中的图像 1,3 Disassembling Nokia 6236i Display: 步骤 2 中的图像 2,3 Disassembling Nokia 6236i Display: 步骤 2 中的图像 3,3
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Front Casing: 步骤 3 中的图像 1,3 Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Front Casing: 步骤 3 中的图像 2,3 Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Front Casing: 步骤 3 中的图像 3,3
    • At the bottom right side of the device, there will be an indention.
    • Insert the head of the 2.5mm screwdriver into the indention.
    • Slide the screwdriver upward to a second indention at the top of the phone.
    • The front casing will detach from the model.
  4. Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Display: 步骤 4 中的图像 1,3 Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Display: 步骤 4 中的图像 2,3 Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Display: 步骤 4 中的图像 3,3
    • Use the flathead screwdriver to remove four screws on the upper half of the phone.
    • Lift the LCD up and off.
结论
2等其他人完成本指南。
Erik Lindahl
于04/18/10注册
63 声望
创作了4篇指南
团队
Cal Poly, Team 10-46, Garner Spring 2010 Cal Poly, Team 10-46, Garner Spring 2010 的会员
CPSU-GARNER-S10S10G46
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,563
