跳转到主内容
Disassembling Nokia 2366i Rear Case
Jonathan Newman
Jonathan Newman6 其他贡献者
最后更新于 September 9, 2017
5 - 10 分钟
中等
不正确的工具
This guide is a step by step procedure to disassemble the base of the phone. It is the preliminary step in gaining access to the inner components of the Nokia 2366i.
你所需要的
工具
查看更多...
  1. Disassembling Nokia 2366i Rear Case, Battery: 步骤 1 中的图像 1,2 Disassembling Nokia 2366i Rear Case, Battery: 步骤 1 中的图像 2,2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Rear Case: 步骤 2 中的图像 1,1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Rear Case: 步骤 3 中的图像 1,3 Disassembling Nokia 2366i Rear Case: 步骤 3 中的图像 2,3 Disassembling Nokia 2366i Rear Case: 步骤 3 中的图像 3,3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Rear Case, Rear Case: 步骤 4 中的图像 1,2 Disassembling Nokia 2366i Rear Case, Rear Case: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
  5. Disassembling Nokia 2366i Rear Case: 步骤 5 中的图像 1,2 Disassembling Nokia 2366i Rear Case: 步骤 5 中的图像 2,2
    • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
    • 2 screws at the bottom
    • 2 screws at the top
  6. Disassembling Nokia 2366i Rear Case: 步骤 6 中的图像 1,2 Disassembling Nokia 2366i Rear Case: 步骤 6 中的图像 2,2
    • Rotate the phone clockwise so the edge is facing you.
    • Insert the spudger in tabs between the outer casing and the inside frame.
    • Slide the spudger upwards.
    • This will remove the rear case of the phone.
  7. Disassembling Nokia 2366i Rear Case: 步骤 7 中的图像 1,1
    • The phone should now be in two different sections.
    • 1) The rear case of the phone.
    • 2) The motherboard and the rest of the phone.
结论
另外一个人完成了本指南。
Jonathan Newman
于01/21/11注册
486 声望
创作了4篇指南
团队
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G14
5 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 1,565
