跳转到主内容
Disassembling Nokia 2366i Front Display
Michael Machado
Michael Machado6 其他贡献者
最后更新于 September 9, 2017
没有估计
中等
Removing a broken front display.
你所需要的
工具
  1. Disassembling Nokia 2366i Front Display, Battery: 步骤 1 中的图像 1,2 Disassembling Nokia 2366i Front Display, Battery: 步骤 1 中的图像 2,2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Front Display: 步骤 2 中的图像 1,1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Front Display: 步骤 3 中的图像 1,3 Disassembling Nokia 2366i Front Display: 步骤 3 中的图像 2,3 Disassembling Nokia 2366i Front Display: 步骤 3 中的图像 3,3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Front Display, Front Cover: 步骤 4 中的图像 1,1
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. Disassembling Nokia 2366i Front Display: 步骤 5 中的图像 1,2 Disassembling Nokia 2366i Front Display: 步骤 5 中的图像 2,2
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  6. Disassembling Nokia 2366i Front Display: 步骤 6 中的图像 1,2 Disassembling Nokia 2366i Front Display: 步骤 6 中的图像 2,2
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
  7. Disassembling Nokia 2366i Front Display, Main Display: 步骤 7 中的图像 1,2 Disassembling Nokia 2366i Front Display, Main Display: 步骤 7 中的图像 2,2
    • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
  8. Disassembling Nokia 2366i Front Display: 步骤 8 中的图像 1,2 Disassembling Nokia 2366i Front Display: 步骤 8 中的图像 2,2
    • Using the spudger, disconnect the green display cable.
  9. Disassembling Nokia 2366i Front Display: 步骤 9 中的图像 1,3 Disassembling Nokia 2366i Front Display: 步骤 9 中的图像 2,3 Disassembling Nokia 2366i Front Display: 步骤 9 中的图像 3,3
    • Lift the metal casing.
    • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
    • Remove the main display from under the metal casing.
  10. Disassembling Nokia 2366i Front Display, Front Display: 步骤 10 中的图像 1,3 Disassembling Nokia 2366i Front Display, Front Display: 步骤 10 中的图像 2,3 Disassembling Nokia 2366i Front Display, Front Display: 步骤 10 中的图像 3,3
    • Fold the metal casing back over.
    • Disconnect the orange front display data cable with the spudger.
    • Hold the phone so that the antenna is facing towards you.
    • Lift up and flip over the metal casing.
  11. Disassembling Nokia 2366i Front Display: 步骤 11 中的图像 1,1
    • Using your fingers, remove the front display.
结论
Michael Machado
于01/21/11注册
334 声望
创作了3篇指南
团队
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G14
5 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 967
