跳转到主内容
Disassembling Nokia 2366i Front Cover
Kristen
Kristen5 其他贡献者
最后更新于 September 9, 2017
没有估计
中等
This guide shows you how to remove the front cover of the phone so that you can access the internal components found there.
你所需要的
工具
  • Spudger
    Spudger
  1. Disassembling Nokia 2366i Front Cover, Battery: 步骤 1 中的图像 1,2 Disassembling Nokia 2366i Front Cover, Battery: 步骤 1 中的图像 2,2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Front Cover: 步骤 2 中的图像 1,1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Front Cover: 步骤 3 中的图像 1,3 Disassembling Nokia 2366i Front Cover: 步骤 3 中的图像 2,3 Disassembling Nokia 2366i Front Cover: 步骤 3 中的图像 3,3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Front Cover, Front Cover: 步骤 4 中的图像 1,1
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. Disassembling Nokia 2366i Front Cover: 步骤 5 中的图像 1,2 Disassembling Nokia 2366i Front Cover: 步骤 5 中的图像 2,2
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  6. Disassembling Nokia 2366i Front Cover: 步骤 6 中的图像 1,2 Disassembling Nokia 2366i Front Cover: 步骤 6 中的图像 2,2
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
结论
另外一个人完成了本指南。
Kristen
于01/17/11注册
175 声望
撰写一个指南
团队
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G14
5 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,197
