跳转到主内容
Disassembling Canon PowerShot SD1100 IS Front and Rear Cover
Tyler Grossheim
Tyler Grossheim3 其他贡献者
最后更新于 January 28, 2014
10分钟
简单
Use this guide to remove the front and rear cover of the Canon PowerShot SD1100 IS.
你所需要的
工具
  1. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover, Front and Rear Cover: 步骤 1 中的图像 1,2 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover, Front and Rear Cover: 步骤 1 中的图像 2,2
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: 步骤 2 中的图像 1,3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: 步骤 2 中的图像 2,3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: 步骤 2 中的图像 3,3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: 步骤 3 中的图像 1,3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: 步骤 3 中的图像 2,3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: 步骤 3 中的图像 3,3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: 步骤 4 中的图像 1,1
    • The cases should now be removed.
结论
3等其他人完成本指南。
Tyler Grossheim
于01/25/11注册
1,524 声望
创作了6篇指南
团队
Cal Poly, Team 3-32, Regan Winter 2011 Cal Poly, Team 3-32, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G32
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 3,478
