跳转到主内容
加入维修社区 - 创建账户
Digiland DL1168A Front/Rear Camera Replacement
你所需要的
  1. Digiland DL1168A Front/Rear Camera Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
    询问修复机器人
    添加评论
  2. Digiland DL1168A Front/Rear Camera Replacement: 步骤 2 中的图像 1,2 Digiland DL1168A Front/Rear Camera Replacement: 步骤 2 中的图像 2,2
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
    询问修复机器人
    添加评论
  3. Digiland DL1168A Front/Rear Camera Replacement: 步骤 3 中的图像 1,2 Digiland DL1168A Front/Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
    询问修复机器人
    添加评论
  4. Digiland DL1168A Front/Rear Camera Replacement, Front/Rear Camera: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to remove the cover that keeps the camera lens in place.
    询问修复机器人
    添加评论
  5. Digiland DL1168A Front/Rear Camera Replacement: 步骤 5 中的图像 1,1
    • Use tweezers to gently begin to lift the back piece off.
    • Lift gently because the lens is connected to the back piece by a small cord.
    询问修复机器人
    添加评论
  6. Digiland DL1168A Front/Rear Camera Replacement: 步骤 6 中的图像 1,1
    • After lifting gently both the lens and the back piece will be removed.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 336
