跳转到主内容
Desktop PC GPU Replacement
Joseph Thompson
Joseph Thompson2 其他贡献者
最后更新于 August 6, 2024
35分钟
简单
社区贡献指南
你所需要的
工具
  1. Desktop PC GPU Replacement, Create an Anti-Static Work Area: 步骤 1 中的图像 1,1
    • Minimize exposure to items that can charge up and produce static electricity.
    • Use an anti-static wrist band.
  2. Desktop PC GPU Replacement, Turn Off Computer: 步骤 2 中的图像 1,1
    • Power off PC via Windows.
    • Switch off Power Supply
  3. Desktop PC GPU Replacement, Unscrew Case Side Panel: 步骤 3 中的图像 1,2 Desktop PC GPU Replacement, Unscrew Case Side Panel: 步骤 3 中的图像 2,2
    • Put screws where you wont lose them
  4. Desktop PC GPU Replacement, Unplug Power Connector to GPU: 步骤 4 中的图像 1,1
    • Be gentle to not pull with to much force when removing power cables.
  5. Desktop PC GPU Replacement, Flip GPU Lock on Motherboard: 步骤 5 中的图像 1,1
    • Try not to touch other components.
    • Gently pull the card out of the slot.
  6. Desktop PC GPU Replacement, Insert New GPU: 步骤 7 中的图像 1,1
    • Verify that the notch in the connector matches the motherboard before sliding in.
    • Carefully slide in GPU until you hear a click on the motherboard.
  7. Desktop PC GPU Replacement, Connect Power Cables: 步骤 8 中的图像 1,1
    • Insert wisdom here.
  8. Desktop PC GPU Replacement, Re-Attach Side Panel: 步骤 9 中的图像 1,1
    • Use same screws from step 2.
    • Flip power supply switch back to on.
    • Plug in PC and turn on.
    • If PC does not post go back through the steps to see if you missed something.
    • Go to manufacturer's website or use the CD that came with the card to download the latest drivers for the GPU to ensure better stability of GPU.
    • Enjoy your new GPU.
结论
另外一个人完成了本指南。
Joseph Thompson
于06/20/19注册
235 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 26
过去 7 天: 84
过去 30 天: 100
总计 516
