跳转到主内容
加入维修社区 - 创建账户
Dell XPS M1530 CPU Replacement
你所需要的
  1. Dell XPS M1530 CPU Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
    询问修复机器人
    添加评论
  2. Dell XPS M1530 CPU Replacement: 步骤 2 中的图像 1,1
    • Push the switch as far to the right as possible to unlock the battery.
    询问修复机器人
    添加评论
  3. Dell XPS M1530 CPU Replacement: 步骤 3 中的图像 1,2 Dell XPS M1530 CPU Replacement: 步骤 3 中的图像 2,2
    • Remove the battery using two hands and pull it away from the computer.
    询问修复机器人
    添加评论
  4. Dell XPS M1530 CPU Replacement, Heat Sink: 步骤 4 中的图像 1,1
    • Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
    • Four 3.9mm Phillips #1 screws
    • One 5.8mm Phillips #1 screw
    询问修复机器人
    添加评论
  5. Dell XPS M1530 CPU Replacement: 步骤 5 中的图像 1,2 Dell XPS M1530 CPU Replacement: 步骤 5 中的图像 2,2
    • Using the highlighted indent, pull up and out to remove the back panel.
    • The indent should provide enough grip to remove the panel with ease.
    询问修复机器人
    添加评论
  6. Dell XPS M1530 CPU Replacement: 步骤 6 中的图像 1,2 Dell XPS M1530 CPU Replacement: 步骤 6 中的图像 2,2
    • First, unscrew the six screws that are holding down the fan and heat sink with a Philips #1 screwdriver. Then use a Phillips #1 to remove the single screw near the bottom of the heat sink.
    • Six Silver Chrome 5.8mm Phillips #1 screws
    • Remove the four screws that are holding down the CPU (the four to the top left that form a rectangle in this image) first. Unscrew them in an X pattern (eg. top left screw, bottom right screw, top right screw, bottom left screw) to minimize risk of harming CPU.
    询问修复机器人
    添加评论
  7. Dell XPS M1530 CPU Replacement: 步骤 7 中的图像 1,2 Dell XPS M1530 CPU Replacement: 步骤 7 中的图像 2,2
    • Carefully lift the fan and heat sink from the laptop.
    • Be careful not to pull up too hard, because the power pin is still connecting the fan to the laptop.
    询问修复机器人
    添加评论
  8. Dell XPS M1530 CPU Replacement: 步骤 8 中的图像 1,1
    • Use your fingers or a spudger to remove the power pin connecting the fan to the laptop by pulling it straight up off the motherboard.
    询问修复机器人
    添加评论
  9. Dell XPS M1530 CPU Replacement: 步骤 9 中的图像 1,1
    • Remove the fan and heat sink from the laptop.
    • When installing the new heat sink, do not forget to replace the thermal paste underneath the heat sink. See iFixit's Applying Thermal Paste guide for further instructions.
    询问修复机器人
    添加评论
  10. Dell XPS M1530 CPU Replacement, CPU: 步骤 10 中的图像 1,1
    • Use a Metal Spudger to turn the black plastic screw to the unlock position from the secure position of the CPU on the motherboard.
    询问修复机器人
    添加评论
  11. Dell XPS M1530 CPU Replacement: 步骤 11 中的图像 1,3 Dell XPS M1530 CPU Replacement: 步骤 11 中的图像 2,3 Dell XPS M1530 CPU Replacement: 步骤 11 中的图像 3,3
    • Carefully remove the CPU by pulling it straight up.
    • CPU Orientation triangle
    • Make sure you pull straight up on the CPU when removing it. Also be careful not to touch the pins on the CPU as they are thin and will bend very easily.
    • The orientation of the CPU is important, locate the corners that has a small triangle. Make sure to match that triangle corner to the upper right corner of the mount that also has a picture of a triangle.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Jase Sasaki
于01/22/15注册
721 声望
创作了5篇指南
团队
Cal Poly, Team 18-4, Maness Winter 2015 Cal Poly, Team 18-4, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G4
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 30
总计 2,001
