跳转到主内容
加入维修社区 - 创建账户
Dell XPS 15 9510 Display Assembly Replacement
你所需要的
    1. Dell XPS 15 9510 Display Assembly Replacement, Lower Case: 步骤 1 中的图像 1,1
      • Make sure the laptop is powered off and unplug all cables before beginning any repair.
      • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
      询问修复机器人
      添加评论
    2. Dell XPS 15 9510 Display Assembly Replacement: 步骤 2 中的图像 1,1
      • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
      • Wedge the case apart with a nylon spudger.
      • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
      • Slide spudger along each side of the laptop
      添加评论
    3. Dell XPS 15 9510 Display Assembly Replacement: 步骤 3 中的图像 1,1
      • Lift the back panel of the laptop off and set it aside.
      添加评论
    1. Dell XPS 15 9510 Display Assembly Replacement, Display Assembly: 步骤 4 中的图像 1,1
      • Remove the four screws (eight total) from each display hinge using a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. Dell XPS 15 9510 Display Assembly Replacement: 步骤 5 中的图像 1,1
      • Remove five screws that connect the display using a Phillips #00 screwdriver.
      添加评论
    3. Dell XPS 15 9510 Display Assembly Replacement: 步骤 6 中的图像 1,1
      • Carefully remove the display from the Dell XPS 15 9510.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
取消:我没有完成这个指南。
Austin Sa
于03/30/22注册
432 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-3, Mellen Spring 2022 UMass Dartmouth, Team 1-3, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S1G3
3 名成员
创作了39篇指南
2指南评论
Missing a very important step.
Two small screws above the display cable clamp - Step 5 - need to be removed. If you look at the picture in step 5, the far left red/orange circle actually contains one. You can spot it inside and at the top of the of the circle. You can't separate the display assembly without removing those 2 screws.
Joshua Kleier - 回复 分享
Aren't there any cables that need to be removed?
Ned Eff - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 116
总计 5,251
