跳转到主内容
加入维修社区 - 创建账户
Dell XPS 14 RAM Replacement
你所需要的
    1. Dell XPS 14 RAM Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Position the computer back side up so that the “XPS” logo is facing you.
      • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
      询问修复机器人
      添加评论
    2. Dell XPS 14 RAM Replacement: 步骤 2 中的图像 1,3 Dell XPS 14 RAM Replacement: 步骤 2 中的图像 2,3 Dell XPS 14 RAM Replacement: 步骤 2 中的图像 3,3
      • Use an opening tool to pry up the metal plate.
      • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    3. Dell XPS 14 RAM Replacement: 步骤 3 中的图像 1,2 Dell XPS 14 RAM Replacement: 步骤 3 中的图像 2,2
      • Use an opening tool to pop out the back panel.
      • Once unhinged, the panel will open away from you.
      • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
      询问修复机器人
      添加评论
    4. Dell XPS 14 RAM Replacement: 步骤 4 中的图像 1,3 Dell XPS 14 RAM Replacement: 步骤 4 中的图像 2,3 Dell XPS 14 RAM Replacement: 步骤 4 中的图像 3,3
      • Flip over the back panel so that the interior of the panel is facing up.
      • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
      • Remove the black plastic cover that holds the disk in place.
      • Remove the back panel.
      • The GCE disk should still be connected to the computer via a purple ribbon cable.
      询问修复机器人
      添加评论
    1. Dell XPS 14 RAM Replacement, Speaker: 步骤 5 中的图像 1,2 Dell XPS 14 RAM Replacement, Speaker: 步骤 5 中的图像 2,2
      • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    2. Dell XPS 14 RAM Replacement: 步骤 6 中的图像 1,2 Dell XPS 14 RAM Replacement: 步骤 6 中的图像 2,2
      • Remove the speaker from its original location so the wire connector is visible.
      • Unplug the red and white cable plug by pulling out the white end tag.
      • The speaker is now fully removed.
      询问修复机器人
      添加评论
    1. Dell XPS 14 RAM Replacement, Battery: 步骤 7 中的图像 1,1
      • Make sure to ground yourself before removing the battery.
      • Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
      • Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    2. Dell XPS 14 RAM Replacement: 步骤 8 中的图像 1,3 Dell XPS 14 RAM Replacement: 步骤 8 中的图像 2,3 Dell XPS 14 RAM Replacement: 步骤 8 中的图像 3,3
      • Detach the battery connector from the motherboard using two thumbs to pop it out.
      • Remove the battery from the laptop.
      询问修复机器人
      添加评论
    1. Dell XPS 14 RAM Replacement, RAM: 步骤 9 中的图像 1,3 Dell XPS 14 RAM Replacement, RAM: 步骤 9 中的图像 2,3 Dell XPS 14 RAM Replacement, RAM: 步骤 9 中的图像 3,3
      • Remove any electrical tape that may be covering or overlapping the RAM cartridge.
      • Push the two metal latches on either side of the RAM outward.
      • The cartridge will pop out of the laptop.
      询问修复机器人
      添加评论
    2. Dell XPS 14 RAM Replacement: 步骤 10 中的图像 1,2 Dell XPS 14 RAM Replacement: 步骤 10 中的图像 2,2
      • Slide the RAM cartridge out of its slot.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 1-3, Botvin Spring 2022 UMass Dartmouth, Team 1-3, Botvin Spring 2022 的会员
UMASSD-BOTVIN-S22S1G3
3 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 29
总计 751
