Dell Vostro 5459 Hard Drive Replacement
Remove the screws that secure the back cover to the computer.
Pry the edges of the back cover from all sides, to release the back cover.
Lift the back cover from the computer.
Disconnect the battery cable from the connector on the system board [1].
Remove the screws that secure the battery to the computer [2].
Lift and remove the battery from the computer [3].
Disconnect the hard drive cable from the connector on the system board [1] .
Remove the screws that secure the hard drive to the computer [2].
Lift the hard drive from the computer [3].
另外一个人完成了本指南。
1指南评论
Dell Vostro 14 5459 definitely is simple and easy to open. In absence of prying tool you can use even disposable plastic knife. Spent 15 minutes to disassemble, change HDD drive to SSD drive and assemble it back. Memory upgrade is easy as well - carefully peel off plastic sheet above RAM module and replace the RAM. Seems particular cooler design is not very prone to collect dust inside too so easier cleaning as well. If middle screw on assembly doesn’t stick in thread, slightly press keyboard in area where keys G,H,J are and try to screw the screw in again. For maintenance and upgrade for this laptop I give 4/5.
