跳转到主内容
Dell Vostro 3450 Display Assembly Replacement
Johnathan Hammond
Johnathan Hammond2 其他贡献者
最后更新于 November 5, 2019
30分钟 - 1小时
中等
社区贡献指南
你所需要的
工具
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
查看更多...
  1. Dell Vostro 3450 Display Assembly Replacement, Unlocking the Battery: 步骤 1 中的图像 1,1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Display Assembly Replacement, Removing the Battery: 步骤 2 中的图像 1,1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Display Assembly Replacement, Prying the Keyboard: 步骤 3 中的图像 1,1
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  4. Dell Vostro 3450 Display Assembly Replacement, Prying the Keyboard retainer: 步骤 4 中的图像 1,1
    • Pry up the second keyboard retainer.
  5. Dell Vostro 3450 Display Assembly Replacement, Pry up the Keyboard Retainer: 步骤 5 中的图像 1,1
    • Pry up the third keyboard retainer.
  6. Dell Vostro 3450 Display Assembly Replacement, Prying the Retainer: 步骤 6 中的图像 1,1
    • Pry up the fourth keyboard retainer.
  7. Dell Vostro 3450 Display Assembly Replacement, Pull up the Keyboard: 步骤 7 中的图像 1,1
    • Pull up the keyboard from the palm rest.
  8. Dell Vostro 3450 Display Assembly Replacement, Release the Latch: 步骤 8 中的图像 1,1
    • Release the latch on the system board connector, then disconnect the keyboard cable.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  9. Dell Vostro 3450 Display Assembly Replacement, Loosen the Screw: 步骤 9 中的图像 1,1
    • Loosen the screw that secures the memory door.
  10. Dell Vostro 3450 Display Assembly Replacement, Removing the Memory Door: 步骤 10 中的图像 1,1
    • Pry up the memory door near the screw hole, lift and remove it.
  11. Dell Vostro 3450 Display Assembly Replacement, Remove the Screw: 步骤 11 中的图像 1,1
    • Remove the screw that secures the optical drive to the computer.
  12. Dell Vostro 3450 Display Assembly Replacement, Prying the Drive: 步骤 12 中的图像 1,1
    • Gently pry the optical drive out of the computer.
  13. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: 步骤 13 中的图像 1,1
    • Remove the screws that secure the optical drive bracket.
  14. Dell Vostro 3450 Display Assembly Replacement, Removing the Optical Drive: 步骤 14 中的图像 1,1
    • Remove the optical drive bracket from the optical drive module.
  15. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: 步骤 15 中的图像 1,1
    • Remove the screws in the battery compartment.
  16. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: 步骤 16 中的图像 1,1
    • Remove the screws in the optical drive compartment.
  17. Dell Vostro 3450 Display Assembly Replacement, Remove the Rubber: 步骤 17 中的图像 1,1
    • Remove the rubber from the bottom base on the right side.
  18. Dell Vostro 3450 Display Assembly Replacement, Remove the Rubber: 步骤 18 中的图像 1,1
    • Remove the rubber from the bottom base on the left side.
  19. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: 步骤 19 中的图像 1,1
    • Remove all the screws from the bottom base.
  20. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: 步骤 20 中的图像 1,1
    • Flip the computer around and remove the screws that secures the palm rest.
  21. Dell Vostro 3450 Display Assembly Replacement, Release the Latches: 步骤 21 中的图像 1,1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  22. Dell Vostro 3450 Display Assembly Replacement, Release the Latch: 步骤 22 中的图像 1,1
    • Release the latch on the system board connector and then disconnect the power button cable.
  23. Dell Vostro 3450 Display Assembly Replacement, Disconnecting the Key Cable: 步骤 23 中的图像 1,1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  24. Dell Vostro 3450 Display Assembly Replacement, Prying the Palm Rest: 步骤 24 中的图像 1,1
    • Pry up the right side of the palm rest.
  25. Dell Vostro 3450 Display Assembly Replacement, Prying the Palm Rest: 步骤 25 中的图像 1,1
    • Pry up the left side of the palm rest.
  26. Dell Vostro 3450 Display Assembly Replacement, Prying the Sides: 步骤 26 中的图像 1,1
    • Pry up the sides of the palm rest and remove it from the computer.
  27. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: 步骤 27 中的图像 1,1
    • Remove the screws that secure the display hinge.
  28. Dell Vostro 3450 Display Assembly Replacement, Loosen the Screw: 步骤 28 中的图像 1,1
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  29. Dell Vostro 3450 Display Assembly Replacement, Disconnecting the LVDS Cable: 步骤 29 中的图像 1,1
    • Disconnect the LVDS cable from the system board.
  30. Dell Vostro 3450 Display Assembly Replacement, Disconnecting the Wireless Cables: 步骤 30 中的图像 1,1
    • Disconnect the wireless local area network (WLAN) antenna cable.
  31. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: 步骤 31 中的图像 1,1
    • Remove the screws that secure the left hinge.
  32. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: 步骤 32 中的图像 1,1
    • Remove the screws that secure the right hinge.
  33. Dell Vostro 3450 Display Assembly Replacement, Lifting the Display Assembly: 步骤 33 中的图像 1,1
    • Lift the display assembly and remove it from the computer.
终点
3等其他人完成本指南。
Johnathan Hammond
于02/28/18注册
45,264 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 938
