跳转到主内容
加入维修社区 - 创建账户
Dell Precision M3800 USB Port Replacement
你所需要的
  1. Dell Precision M3800 USB Port Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell Precision M3800 USB Port Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
    添加评论
  2. Dell Precision M3800 USB Port Replacement: 步骤 2 中的图像 1,1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
    询问修复机器人
    添加评论
  3. Dell Precision M3800 USB Port Replacement, Battery: 步骤 3 中的图像 1,1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
    询问修复机器人
    添加评论
  4. Dell Precision M3800 USB Port Replacement, USB Port: 步骤 4 中的图像 1,3 Dell Precision M3800 USB Port Replacement, USB Port: 步骤 4 中的图像 2,3 Dell Precision M3800 USB Port Replacement, USB Port: 步骤 4 中的图像 3,3
    • Disconnect the orange wire with the two pull tabs by pulling upwards on the pull tabs.
    询问修复机器人
    添加评论
  5. Dell Precision M3800 USB Port Replacement: 步骤 5 中的图像 1,3 Dell Precision M3800 USB Port Replacement: 步骤 5 中的图像 2,3 Dell Precision M3800 USB Port Replacement: 步骤 5 中的图像 3,3
    • Remove the single 3.5 mm screw at the top of the left side holding the silver bracket using a Phillips #00 screwdriver.
    • Remove the LAN chip by pulling from the top away from the connector.
    询问修复机器人
    添加评论
  6. Dell Precision M3800 USB Port Replacement: 步骤 6 中的图像 1,3 Dell Precision M3800 USB Port Replacement: 步骤 6 中的图像 2,3 Dell Precision M3800 USB Port Replacement: 步骤 6 中的图像 3,3
    • Disconnect the wires that are connected to left side of the motherboard with a hooked prying tool.
    询问修复机器人
    添加评论
  7. Dell Precision M3800 USB Port Replacement: 步骤 7 中的图像 1,2 Dell Precision M3800 USB Port Replacement: 步骤 7 中的图像 2,2
    • Disconnect the black wire that is connected to left side of the motherboard.
    询问修复机器人
    添加评论
  8. Dell Precision M3800 USB Port Replacement: 步骤 8 中的图像 1,3 Dell Precision M3800 USB Port Replacement: 步骤 8 中的图像 2,3 Dell Precision M3800 USB Port Replacement: 步骤 8 中的图像 3,3
    • Unscrew the three 3.5 mm screws that secure the circuit board using a Phillips #00 screwdriver.
    • Remove the circuit board by lifting upward.
    • To fully remove the USB ports from the circuit board, you'll need to desolder the points. Use the How to Solder and Desolder Connections guide for more information on soldering and desoldering connections.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 38
总计 1,058
