跳转到主内容
Dell Optiplex 745 Small Form Factor Motherboard Replacement
Alexander Rosner
Alexander Rosner 另一个贡献者
最后更新于 August 17, 2019
10 - 20 分钟
中等
In this guide, we will be removing parts of the computer from the motherboard to be able to take the board itself out.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: 步骤 1 中的图像 1,2 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: 步骤 1 中的图像 2,2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 2 中的图像 1,2 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 2 中的图像 2,2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Disconnect all of the cords that are connected to the motherboard.
    • Press in the lever on the side of the male end, and then pull out.
    • Pull cord straight out.
    • Disconnect the front plate (USB and audio output) from the motherboard.
    • Some of the cords in the pictures are missing due to the condition of our device when creating this guide.
  4. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 4 中的图像 1,3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 4 中的图像 2,3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 4 中的图像 3,3
    • Remove the graphics card.
    • Lift the blue latch on the fat end of the graphics card.
    • Pull the blue lever on the skinny end of the graphics card toward the power supply.
    • Pull out one end of the card at a time.
  5. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 5 中的图像 1,3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 5 中的图像 2,3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 5 中的图像 3,3
    • Remove the heat sink.
    • Unscrew the (2) two screws using a Phillips #2 screwdriver and lift out the heat sink.
  6. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 6 中的图像 1,3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 6 中的图像 2,3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 6 中的图像 3,3
    • Remove the (5) five 6mm Phillips #2 screws from the motherboard.
    • Remove the (2) two 17mm Phillips #2 screws from the mount for the heat sink.
  7. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 7 中的图像 1,3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 7 中的图像 2,3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 步骤 7 中的图像 3,3
    • Remove the back plate by lifting straight out by the blue latch that secures the graphics card.
    • Pull the end of the motherboard closest to the back of the computer away from the static back plate.
    • Lift this end away and out of the case.
结论
7等其他人完成本指南。
团队
USF Tampa, Team S5-G5, Walkup Fall 2017 USF Tampa, Team S5-G5, Walkup Fall 2017 的会员
USFT-WALKUP-F17S5G5
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 15
总计 1,959
