跳转到主内容
Dell Latitude E6400 Screen Replacement
D. K. Labudek
D. K. Labudek 另一个贡献者
最后更新于 November 27, 2023
30分钟 - 1小时
中等
社区贡献指南
你所需要的
工具
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Dell Latitude E6400 Screen Replacement, Battery Removal: 步骤 1 中的图像 1,3 Dell Latitude E6400 Screen Replacement, Battery Removal: 步骤 1 中的图像 2,3 Dell Latitude E6400 Screen Replacement, Battery Removal: 步骤 1 中的图像 3,3
    • Disconnect AC power adaptor
    • Push battery release tabs inwards.
    • Slide the battery out of the computer.
  2. Dell Latitude E6400 Screen Replacement, Display Plastic Lids: 步骤 2 中的图像 1,3 Dell Latitude E6400 Screen Replacement, Display Plastic Lids: 步骤 2 中的图像 2,3 Dell Latitude E6400 Screen Replacement, Display Plastic Lids: 步骤 2 中的图像 3,3
    • Remove the two 4.8mm Phillips screws securing the plastic lids.
    • Slide the plastic lids of the case
  3. Dell Latitude E6400 Screen Replacement, Display Data Cable: 步骤 3 中的图像 1,2 Dell Latitude E6400 Screen Replacement, Display Data Cable: 步骤 3 中的图像 2,2
    • Grab the plastic pull tab secured to the display data cable lock and pull the display data cable connector straight up from its socket.
    • De-route the display data cable from the channel.
  4. Dell Latitude E6400 Screen Replacement, Wi-Fi Antenna Cable: 步骤 4 中的图像 1,2 Dell Latitude E6400 Screen Replacement, Wi-Fi Antenna Cable: 步骤 4 中的图像 2,2
    • Using spudger lift and disconnect Wi-Fi antenna cable.
    • De-route the Wi-Fi antenna cable from it's channel.
  5. Dell Latitude E6400 Screen Replacement, Display Assembly: 步骤 5 中的图像 1,3 Dell Latitude E6400 Screen Replacement, Display Assembly: 步骤 5 中的图像 2,3 Dell Latitude E6400 Screen Replacement, Display Assembly: 步骤 5 中的图像 3,3
    • Open your laptop so the display is perpendicular to the upper case.
    • Place your opened MacBook on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the two 4.8 mm Phillips screws from the display brackets.
    • Grab the upper case with your right hand and rotate the display slightly away from the upper case. Lift the display away from the upper case, minding any brackets or cables that may get caught.
结论
D. K. Labudek
于03/09/18注册
685 声望
创作了4篇指南
2指南评论
How to fix the flickering of screen in Dell latitude E6400
Surprisesipho - 回复
I would start with resetting the connectors on motherboard side and then on the screen side. Then I would try replacing cables. Anything above that would require multimeter knowledge. Always start from cheapest to more expensive.
D. K. Labudek -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 623
