跳转到主内容
Dell Latitude E6400 Hard Drive Replacement
Aaron Thomas
Aaron Thomas2 其他贡献者
最后更新于 November 16, 2022
5 - 10 分钟
中等
不一致的图片
需要更多图片
社区贡献指南
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
    • First, turn off your laptop and disconnect any external adapter.
  1. Dell Latitude E6400 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Release the latch or latches connected to the battery that hold it in place.
  2. Dell Latitude E6400 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the old battery from its storage bay.
    • Plug in the external AC adapter to fully charge the new battery.
  3. Dell Latitude E6400 Hard Drive Replacement, Remove the hard drive: 步骤 5 中的图像 1,1
    • After removing the battery, locate and remove the two M3 x 3-mm screws securing the hard drive to the base assembly. Then, slide the hard drive from the base assembly.
  4. Dell Latitude E6400 Hard Drive Replacement, Remove the hard drive bezel: 步骤 6 中的图像 1,1
    • Next, remove the M3 x 3-mm screw on the hard drive bezel and remove the hard drive bezel. NOTE: Be mindful not to touch the components of the drive. Doing so could damage the drive.
结论
With your replacement hard drive, reassemble your device by performing the instructions above in reverse order.
Aaron Thomas
于02/16/21注册
1,224 声望
创作了10篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
2条评论
Easy hard drive replacement!
Jeffrey P - 回复
Buenas tardes mi dell e6400 al reproducir video o música de escucha con disco rayado y el video se pausa. Me podrían apoyar para su reparación
Arbey Gatica Sambrano - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 47
总计 1,587
