跳转到主内容
Dell Latitude E6330 Screen Replacement
Brett Murray
Brett Murray4 其他贡献者
最后更新于 August 28, 2024
20 - 40 分钟
中等
需要更好的图片
If your Dell Latitude E6330 has physical cracks or shattered glass that impacts visibility, or unusual colors, lines on the display or sometimes the screen remains dark even though the laptop is powered on. Use this guide to replace your screen and fix these problems.
The screen is an essential component of your laptop. Damage to the screen can significantly impair the usability of your device. By following this guide, you will be able to replace the screen and restore your laptop's functionality.
Before starting this guide make sure that your Dell Latitude is completely powered off.
你所需要的
工具
  1. Dell Latitude E6330 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off computer by holding down the power button
  2. Dell Latitude E6330 Screen Replacement: 步骤 2 中的图像 1,3 Dell Latitude E6330 Screen Replacement: 步骤 2 中的图像 2,3 Dell Latitude E6330 Screen Replacement: 步骤 2 中的图像 3,3
    • Slide latches out to unlock and remove battery.
  3. Dell Latitude E6330 Screen Replacement, Screen: 步骤 3 中的图像 1,1
    • Open the laptop and unscrew the 2.5 X 3mm screw in the bottom center of screen
  4. Dell Latitude E6330 Screen Replacement: 步骤 4 中的图像 1,1
    • Using a spudger, carefully remove of the exterior black frame/cover of the screen
  5. Dell Latitude E6330 Screen Replacement: 步骤 5 中的图像 1,1
    • Using a Philips head screw driver, screw the ten surrounding 2.5 X 3mm screws on the frame of the screen
  6. Dell Latitude E6330 Screen Replacement: 步骤 6 中的图像 1,1
    • Detach the yellow LCD inverted from the back of the screen
  7. Dell Latitude E6330 Screen Replacement: 步骤 7 中的图像 1,1
    • Carefully pull off the screen itself
结论
Brett Murray
于03/21/19注册
399 声望
创作了3篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 930
