跳转到主内容
Dell Latitude E6330 Keyboard Replacement
Brett Murray
Brett Murray6 其他贡献者
最后更新于 January 9, 2025
20 - 30 分钟
中等
需要更好的图片
The Dell Latitude E6330 is a durable and reliable business laptop, but over time, the keyboard may experience wear and tear from heavy usage. Whether you’re dealing with unresponsive keys, sticky buttons, or a cracked keyboard, replacing it can breathe new life into your device.
This guide will walk you through the process of safely removing and replacing the keyboard on a Dell Latitude E6330, ensuring minimal risk to other components.
Before beginning, make sure to power off the laptop, disconnect the battery, and have the necessary tools on hand. With this guide, you’ll have your laptop back to peak performance in no time!
你所需要的
工具
  1. Dell Latitude E6330 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Dell Latitude E6330 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Start by flipping the laptop over and removing the two, deeply recessed, 2.5mm x 5mm screws from the bottom face of the laptop.
  2. Dell Latitude E6330 Keyboard Replacement: 步骤 2 中的图像 1,3 Dell Latitude E6330 Keyboard Replacement: 步骤 2 中的图像 2,3 Dell Latitude E6330 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Grab a plastic spunger and slowly pop out the keyboard bezel from around the keyboard.
  3. Dell Latitude E6330 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Locate and remove the remaining three 2mm x 3mm screws connecting the keyboard to the frame. (One is located just left of the left mouse button and the remaining two are just right of the right mouse button).
  4. Dell Latitude E6330 Keyboard Replacement: 步骤 4 中的图像 1,3 Dell Latitude E6330 Keyboard Replacement: 步骤 4 中的图像 2,3 Dell Latitude E6330 Keyboard Replacement: 步骤 4 中的图像 3,3
    • At this time you should be able to gently lift the keyboard off of the frame and expose a ribbon cable connecting it to the motherboard. Flip up the clip holding the ribbon in place and remove the faulty keyboard.
    • When connecting the new ribbon cable make sure you gently slide it into its slot before locking the latch back down to ensure it is properly connected.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2等其他人完成本指南。
Brett Murray
于03/21/19注册
399 声望
创作了3篇指南
团队
1指南评论
That's the way to do it!
goran ninkovic - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 18
总计 1,115
