Dell Latitude E5410 Coin-Cell Battery Replacement
3 - 5 分钟
简单
社区贡献指南
你所需要的
配件
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
After removing the battery, loosen the screw that secures the access panel to the computer. Then, lift up the access panel at an angle and remove it from the computer.
Disconnect the coin-cell battery cable from the system board.
Slide the coin-cell battery from its socket.
即将完成!
With you new battery, reassemble your device by performing the instructions above in reverse order.
结论
