跳转到主内容
Dell Latitude E5400 Memory Upgrade / Replacement
Robin Koch
Robin Koch 另一个贡献者
最后更新于 August 9, 2017
10分钟
简单
社区贡献指南
你所需要的
工具
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
查看更多...
  1. Dell Latitude E5400 Memory Upgrade / Replacement, Remove battery: 步骤 1 中的图像 1,1
    • Be sure to remove the battery to prevent any electrical shortage.
  2. Dell Latitude E5400 Memory Upgrade / Replacement, Remove the backpanel: 步骤 2 中的图像 1,2 Dell Latitude E5400 Memory Upgrade / Replacement, Remove the backpanel: 步骤 2 中的图像 2,2
    • Losen all four screws and remove the backpanel.
    • Remove the backpanel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
  3. Dell Latitude E5400 Memory Upgrade / Replacement, change/upgrade the memory: 步骤 3 中的图像 1,1
    • Now you can upgrade or change the memory.
    • NOTE: If the laptop doesnt boot after the upgrade, make sure the ram is fully inserted. Still doesnt boot? Try another memory stick.
结论
另外一个人完成了本指南。
Robin Koch
于03/25/17注册
289 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 2,188
