跳转到主内容
Dell Latitude E4300 Keyboard Replacement
Maritza Martinez
Maritza Martinez 另一个贡献者
最后更新于 January 3, 2019
2 - 5 分钟
非常容易
The keyboard is a crucial component to your laptop and because it is fragile there is a higher risk of breaking. Use this replacement guide to replace your keyboard. Make sure that you are careful when working with the keyboard because of its fragility. The keyboard must also be removed if you are attempting to replace any components within the laptop, for example, the hard drive or motherboard.
你所需要的
工具
  1. Dell Latitude E4300 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Open the laptop and remove the small panel located above the keyboard.
  2. Dell Latitude E4300 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
  3. Dell Latitude E4300 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Pull off keyboard forward and then outwards.
    • The keyboard is fragile, so make sure you pull the keyboard off carefully.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 763
