跳转到主内容
Dell Latitude D600 RAM (Main Memory) Replacement
Joseph
Joseph 另一个贡献者
最后更新于 August 18, 2014
5分钟
简单
社区贡献指南
This guide will show how to add RAM or replace existing RAM on the Latitude D600
你所需要的
工具
  1. Dell Latitude D600 RAM (Main Memory) Replacement, Battery: 步骤 1 中的图像 1,1
    • Find the battery
  2. Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 2 中的图像 1,2 Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 2 中的图像 2,2
    • Pull the tab to release the battery
  3. Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out
  4. Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): 步骤 4 中的图像 1,2 Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): 步骤 4 中的图像 2,2
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  5. Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 5 中的图像 1,3 Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 5 中的图像 2,3 Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 5 中的图像 3,3
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  6. Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 6 中的图像 1,1
    • Once the RAM is popped up, slowly pull it out of the slot
  7. Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 7 中的图像 1,3 Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 7 中的图像 2,3 Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 7 中的图像 3,3
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  8. Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 8 中的图像 1,1
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
结论
6等其他人完成本指南。
Joseph
于07/16/14注册
1,497 声望
创作了5篇指南
1指南评论
Almost perfect: easy; clear;
Herman - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 2,918
