跳转到主内容
Dell Inspiron n5110 heat sink and thermal paste replacement
ZFix
ZFix5 其他贡献者
最后更新于 March 29, 2024
1 - 2 小时
中等
社区贡献指南
If your laptop overheat, you must open it and clean the Heat-Sink system. This video will show you how to do this.
Please SUBSCRIBE to my channel ツ
你所需要的
配件
工具
查看更多...
视频概述
  1. Dell Inspiron n5110 heat sink and thermal paste replacement, Heat Sink System Cleaning / Thermal Paste Replacing: 步骤 1 中的图像 1,3 Dell Inspiron n5110 heat sink and thermal paste replacement, Heat Sink System Cleaning / Thermal Paste Replacing: 步骤 1 中的图像 2,3 Dell Inspiron n5110 heat sink and thermal paste replacement, Heat Sink System Cleaning / Thermal Paste Replacing: 步骤 1 中的图像 3,3
    • Switch-off the laptop and remove the battery.
    • To remove the keyboard lift it from one side by using cutter. Now open 4x locking clips at the upper side on the keyboard.
  2. Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 2 中的图像 1,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 2 中的图像 2,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 2 中的图像 3,3
    • Open the keyboard flex cable connector and remove the KB.
    • Open the RAM memory cover.
    • The DVD drive is held by one screw. After unscrewing, you can remove the drive.
  3. Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 3 中的图像 1,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 3 中的图像 2,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 3 中的图像 3,3
    • 12x screws M 2,5x5,0
    • 4x screws M 2,5x5,0
    • Power switch cable connector
    • Mouse pad cable connector
    • Hot keys cable connector
    • After removing all the screws and opening all the connectors, you can remove the upper case.
  4. Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 4 中的图像 1,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 4 中的图像 2,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 4 中的图像 3,3
    • Eject the Card Reader Blanking Plate.
    • Disconnect the LCD display flex cable.
    • Disconnect the WiFi and Bluetooth coaxial cables.
    • The LCD display hings are held by 4x M 2,5x5.0 screws.
    • Now you can remove the LCD display module.
  5. Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 5 中的图像 1,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 5 中的图像 2,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 5 中的图像 3,3
    • Unscrew 5x M2.5x5.0 screws.
    • Disconnect the Loudspeakers cable connector.
    • Remove the Daughter Bluetooth board.
    • Start removing the mother board by lifting from the right side (near to the DVD drive connector).
    • Be careful, there are connectors between mother board and another two additional small boards (charging port board and USB connectors, WiFi card slot board).
  6. Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 6 中的图像 1,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 6 中的图像 2,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 6 中的图像 3,3
    • Remove the Hard Disk drive.
    • Disconnect the Fan cable connector.
  7. Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 7 中的图像 1,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 7 中的图像 2,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 7 中的图像 3,3
    • Remove the Heat Sink system.
    • Clean the cooper contact surface.
  8. Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 8 中的图像 1,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 8 中的图像 2,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 8 中的图像 3,3
    • Disassemble the Heat Sink system to clean the fan and the radiator from inside.
  9. Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 9 中的图像 1,2 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 9 中的图像 2,2
    • Clean the old thermal paste / compose from the CPU.
  10. Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 10 中的图像 1,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 10 中的图像 2,3 Dell Inspiron n5110 heat sink and thermal paste replacement: 步骤 10 中的图像 3,3
结论
19等其他人完成本指南。
ZFix
于12/09/13注册
194,171 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
326 名成员
创作了1,672篇指南
2指南评论
Which thermal paste would you recommend?
PinupSquid - 回复
Done! It works, now my laptop is as new!
alexmogavero - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 53
总计 22,701
