跳转到主内容
Dell Inspiron M5010 Display Assembly Replacement
Terrence15
Terrence15 另一个贡献者
最后更新于 November 22, 2019
2 - 6 分钟
中等
社区贡献指南
In this guide, we will be showing you how to remove and replace the Display Assembly.
你所需要的
工具
  1. Dell Inspiron M5010 Display Assembly Replacement, Remove the Screws: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over and remove the two screws.
  2. Dell Inspiron M5010 Display Assembly Replacement, Disconnect the Cables: 步骤 2 中的图像 1,1
    • Disconnect the Mini-Card antenna cables from the Mini-Card.
  3. Dell Inspiron M5010 Display Assembly Replacement, Disconnect the Display Cable: 步骤 3 中的图像 1,1
    • Disconnect the display cable from the connector on the system board and remove it from the routing guide.
  4. Dell Inspiron M5010 Display Assembly Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Remove the four screws (two on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron M5010 Display Assembly Replacement, Lifting the Display Assembly: 步骤 5 中的图像 1,1
    • Lift and remove the display assembly out of the computer base.
  6. Dell Inspiron M5010 Display Assembly Replacement, Placing the Display Assembly: 步骤 6 中的图像 1,1
    • Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
  7. Dell Inspiron M5010 Display Assembly Replacement, Route the Display Cable: 步骤 7 中的图像 1,1
    • Route the display cable into the routing guide and connect the cable to the connector on the system board.
  8. Dell Inspiron M5010 Display Assembly Replacement, Connecting the Mini-Card Antenna Cables: 步骤 8 中的图像 1,1
    • Connect the Mini-Card antenna cables to the connectors on the Mini- Card.
  9. Dell Inspiron M5010 Display Assembly Replacement, Replace the Screws: 步骤 9 中的图像 1,1
    • Turn the computer over and replace the two screws at the bottom of the computer.
终点
另外一个人完成了本指南。
Terrence15
于12/18/17注册
79,555 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 227
