跳转到主内容
Dell Inspiron 8600 Touch Pad Replacement
John Nesthus
John Nesthus8 其他贡献者
最后更新于 January 10, 2025
1 - 2 小时
中等
动态照片拍摄
需要更多图片
不正确的工具
缺少的步骤
更好的介绍
In this guide, you will learn how to replace the touchpad on the Dell Inspiron 8600. The touchpad is used to scroll and click on links and items that are being presented on your screen without this function working properly your computer is ineffective.
Before you start the repair, make sure your laptop is powered off and it is unplugged from the charger.
你所需要的
工具
  1. Dell Inspiron 8600 Touch Pad Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: 步骤 2 中的图像 1,3 Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: 步骤 2 中的图像 2,3 Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: 步骤 2 中的图像 3,3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Touch Pad Replacement: 步骤 3 中的图像 1,1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Touch Pad Replacement, Keyboard: 步骤 4 中的图像 1,3 Dell Inspiron 8600 Touch Pad Replacement, Keyboard: 步骤 4 中的图像 2,3 Dell Inspiron 8600 Touch Pad Replacement, Keyboard: 步骤 4 中的图像 3,3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Dell Inspiron 8600 Touch Pad Replacement, Display Module: 步骤 5 中的图像 1,2 Dell Inspiron 8600 Touch Pad Replacement, Display Module: 步骤 5 中的图像 2,2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  6. Dell Inspiron 8600 Touch Pad Replacement: 步骤 6 中的图像 1,1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  7. Dell Inspiron 8600 Touch Pad Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 8600 Touch Pad Replacement: 步骤 7 中的图像 2,2
    • Lift the display module directly upwards from the base of the computer.
  8. Dell Inspiron 8600 Touch Pad Replacement: 步骤 8 中的图像 1,1
    • Now remove the display module.
  9. Dell Inspiron 8600 Touch Pad Replacement, Touch Pad: 步骤 9 中的图像 1,1
    • Remove the palm rest assembly that secures the touch pad from the device.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
John Nesthus
于04/13/11注册
186 声望
创作了6篇指南
团队
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G22
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 3,099
