跳转到主内容
Dell Inspiron 8600 Power Button Replacement
Brian Murphy
Brian Murphy7 其他贡献者
最后更新于 March 3, 2016
15 - 30 分钟
简单
动态照片拍摄
需要更多图片
不正确的工具
We will show you how to remove and replace the hinge cover which houses the power button.
你所需要的
工具
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
查看更多...
  1. Dell Inspiron 8600 Power Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Power Button Replacement, Power Button: 步骤 2 中的图像 1,3 Dell Inspiron 8600 Power Button Replacement, Power Button: 步骤 2 中的图像 2,3 Dell Inspiron 8600 Power Button Replacement, Power Button: 步骤 2 中的图像 3,3
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Dell Inspiron 8600 Power Button Replacement: 步骤 3 中的图像 1,1
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
结论
3等其他人完成本指南。
Brian Murphy
于04/13/11注册
368 声望
创作了4篇指南
团队
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G22
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 4,175
