简介
If you are having difficulties with the keyboard, please follow this guide.
工具
配件
没有特定配件。
Remove the battery from the bottom of the laptop.
Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
Insert a spludger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spludger between the hinge and the top cover.
Remove the screws at the top of the keyboard as indicated.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
The keyboard should be easily removable at this point.
2等其他人完成本指南。
一条评论
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
fordsmtack - 回复
