跳转到主内容
Dell Inspiron 7573 2-in-1 Hard Drive Replacement
Kylie Freese
Kylie Freese2 其他贡献者
最后更新于 November 16, 2022
30分钟
中等
This guide will walk you through how remove the hard drive from the systems board of your Dell Inspiron 7573 2-in-1 computer. This guide is useful for replacing a hard drive that may be defective or damaged. Complications such as file issues on your computer or data malfunctions may cause you to replace the hard drive.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
查看更多...
  1. Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
  5. Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,3 Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,3 Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 3,3
    • Using the pull-tab, disconnect the hard drive cable from the motherboard.
    • In a laptop containing a hard drive, the other end of the cable will be seated in the hard drive under the silver cover. The device used in this guide was lacking one, so the cable appears loose.
  6. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the three 3 mm screws that secure the hard-drive assembly using a Phillips #00 screwdriver.
  7. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Disconnect the hard drive cable from the hard drive.
  8. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Lift the right speaker by releasing the rubber grommets from the slots on the palm-rest assembly.
  9. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Remove the four 3 mm screws that secure the hard drive bracket to the hard drive with a Phillips #00 screwdriver.
  10. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 步骤 10 中的图像 1,1
    • Lift up the hard drive and replace it.
结论
Kylie Freese
于09/27/21注册
453 声望
创作了3篇指南
团队
Casper College, Team 1-2, Lareau Fall 2021 Casper College, Team 1-2, Lareau Fall 2021 的会员
CASC-LAREAU-F21S1G2
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 30
总计 1,217
