跳转到主内容
Dell Inspiron 3552 Memory Module  Replacement
Jordon Dozier
Jordon Dozier 另一个贡献者
最后更新于 June 17, 2021
没有估计
中等
语法警察
编辑中
社区贡献指南
  1. Dell Inspiron 3552 Memory Module  Replacement, Removing the battery: 步骤 1 中的图像 1,1
    • Close the display and turn the computer over
    • Slide the battery-release latch to the unlocked position
    • Lift the battery at an angle and remove the battery from the battery bay.
    • Turn the computer over, open the display, and press the power button for five seconds to ground the system board
  2. Dell Inspiron 3552 Memory Module  Replacement, removing memory module: 步骤 2 中的图像 1,1
    • Using your fingertips, spread apart the securing clips at each end of the memory-module slot until the memory module pops up.
    • Slide and remove the memory module from the memory-module slot.
  3. Dell Inspiron 3552 Memory Module  Replacement, Replacing Ram: 步骤 3 中的图像 1,1
    • Align the notch on the memory module with the tab on the memory-module slot.
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
结论
另外一个人完成了本指南。
Jordon Dozier
于02/10/21注册
1,663 声望
创作了12篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 42
