Dell Inspiron 3552 Hard Drive Replacement Part 1
简介
转到步骤 1part 2: Dell Inspiron 3552 Hard drive Replacement part 2 - iFixit Repair Guide
Close the display and turn the computer over
Slide the battery-release latch to the unlocked position
Lift the battery at an angle and remove the battery from the battery bay
Remove the screw that secures the optical-drive assembly to the base cover.
Using a plastic scribe, push the optical-drive assembly out of the optical-drive bay.
Pull the optical-drive assembly out of the optical-drive bay.
Turn on the computer over and open the display
Using a plastic scribe, gently release the tabs that secure the keyboard to the palm-rest assembly
Slide the keyboard up to release it from the slots on the palm-rest assembly.
Carefully turn the keyboard over and place it on the palm-rest assembly
Open the display and remove the screws that secure the palm-rest assembly to the base cover from its connector on the system board
Open the latch and disconnect the optical-drive cable from its connector on the system board
Close the display and turn the computer over.
Remove the screws that secure the base cover to the palm-rest assembly
Using your fingertips, gently pry the base cover off the palm-rest assembly
Release the optical-drive interposer from the tabs on the base cover.
另外一个人完成了本指南。
