跳转到主内容
Dell Inspiron 3542 LCD screen replacement
你所需要的
  1. Dell Inspiron 3542 LCD screen replacement, Remove the battery: 步骤 1 中的图像 1,2 Dell Inspiron 3542 LCD screen replacement, Remove the battery: 步骤 1 中的图像 2,2
    • Remove the battery by pushing both clips out.
    • Remove the power supply.
    • Use Jimmy or another opening tool to remove the screen bezel. Be careful not to damage the bezel.
  2. Dell Inspiron 3542 LCD screen replacement, Screen removal: 步骤 3 中的图像 1,2 Dell Inspiron 3542 LCD screen replacement, Screen removal: 步骤 3 中的图像 2,2
    • Loosen the marked screws.
  3. Dell Inspiron 3542 LCD screen replacement, Screen removal: 步骤 4 中的图像 1,1
    • Remove the marked screws.
  4. Dell Inspiron 3542 LCD screen replacement, Screen removal: 步骤 5 中的图像 1,1
    • The screen can now be removed safely. You can put it screen down at your keyboard.
    • Be careful with the screen.
    • Be careful you don't break the cable connecting the screen.
    • Remove the sticker holding the cable in place.
    • Use Tweezer to remove the safety holding the cable in place.
    • Use Spudger to remove the cable connecting the screen. Be careful whilst removing it.
结论
Grab your new screen and do all the steps in reverse order.
4等其他人完成本指南。
由衷感谢以下译者:
nl en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 27
总计 2,547
