Dell Inspiron 3520 Screen Replacement
简介
转到步骤 1This repair process includes the removal of small screws from the computer. Make sure these screws are stored in a clean area where they can be easily found. This process also goes into the computer internals, therefore, be delicate with the removal of the electronic internal components as they may be very fragile.
Turn off notebook
Set the notebook upside down with the battery facing away from you.
Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
Locate the four tabs along the top edge of the keyboard.
Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
Locate and remove the 14 (5mm) Phillips #00 screws from the bottom of the laptop.
Locate and remove the two 5mm Phillips #00 screws found under the keyboard.
Disconnect the two controlling wires with the blue pull tabs.
5等其他人完成本指南。
