跳转到主内容
Dell Inspiron 3148 Fan Replacement
Christopher Gravelle
Christopher Gravelle2 其他贡献者
最后更新于 May 7, 2024
10 - 15 分钟
中等
动态照片拍摄
Is your computer heating up easily or getting louder? Consider using this guide to replace the fan in your device.
你所需要的
工具
查看更多...
  1. Dell Inspiron 3148 Fan Replacement, Back Panel: 步骤 1 中的图像 1,2 Dell Inspiron 3148 Fan Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 Fan Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 Fan Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 3148 Fan Replacement: 步骤 3 中的图像 2,2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 Fan Replacement, Fan: 步骤 4 中的图像 1,3 Dell Inspiron 3148 Fan Replacement, Fan: 步骤 4 中的图像 2,3 Dell Inspiron 3148 Fan Replacement, Fan: 步骤 4 中的图像 3,3
    • If there is tape on your fan, remove the tape.
    • Remove the two 2mm screws on the fan enclosure using the Phillips #00 screwdriver.
  5. Dell Inspiron 3148 Fan Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 3148 Fan Replacement: 步骤 5 中的图像 2,2
    • Unscrew the three 4mm screws holding down the heat sink of the fan using the Phillips #00 screwdriver.
    • The three 4mm screws found in the heat sink will remain attached to the heat sink. This is okay as long as they are detached from the motherboard.
  6. Dell Inspiron 3148 Fan Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tweezers to gently pull the power supply cable from its port.
  7. Dell Inspiron 3148 Fan Replacement: 步骤 7 中的图像 1,1
    • Grasp the fan and lift upward. Remove the fan from the device.
结论
团队
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 UMass Dartmouth, Team S1-G2, Simcock Fall 2018 的会员
UMASSD-SIMCOCK-F18S1G2
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 241
