跳转到主内容
Dell Inspiron 17R-N7110 Battery Replacement
Emily Cone
Emily Cone7 其他贡献者
最后更新于 March 7, 2024
45秒 - 1分钟
非常容易
If you have narrowed down the cause of your laptop's problems to the battery, this guide will explain how to remove and replace your battery to restore normal function to your device. Replacing the battery is very simple.
你所需要的
  1. Dell Inspiron 17R-N7110 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 17R-N7110 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 17R-N7110 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    • Do not touch any electronic components without wearing the anti-static wrist strap. Failure to do so poses a risk of static electric shock, and may cause damage to components.
    • Place the laptop on a flat surface with the Dell logo upside down.
    • Flip the laptop over. The battery will be in the top center.
  2. Dell Inspiron 17R-N7110 Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17R-N7110 Battery Replacement: 步骤 2 中的图像 2,2
    • Slide both the left lock and right lock, towards the center of the battery.
    • Push upwards on the grip on the bottom of the battery to remove it.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 34
总计 1,530
