跳转到主内容
Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement
Delia Padilla
Delia Padilla2 其他贡献者
最后更新于 December 28, 2022
1分钟
非常容易
The base cover of the Dell Inspiron 17" 7786 2-in-1 laptop is made with silver aluminum-clad, holding 3 captive screws near the area where the hinges are located.
While the device does have good ventilation for everyday usage, it would be advised to remove the casing to clean any hidden dust and debris.
你所需要的
工具
  1. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement, Base Cover: 步骤 1 中的图像 1,2 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement, Base Cover: 步骤 1 中的图像 2,2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: 步骤 2 中的图像 2,2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: 步骤 3 中的图像 3,3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: 步骤 4 中的图像 3,3
    • Carefully remove the base cover from the laptop.
结论
Delia Padilla
于08/23/22注册
588 声望
创作了5篇指南
团队
Gateway, Team 1-3, Class Fall 2022 Gateway, Team 1-3, Class Fall 2022 的会员
GCC-CLASS-F22S1G3
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 19
总计 187
