跳转到主内容
Dell Inspiron 17-7746 RAM Replacement
Joshua Plagerman
Joshua Plagerman4 其他贡献者
最后更新于 August 5, 2019
10 - 15 分钟
中等
This very easy guide is also helpful if one wants to upgrade their RAM of their device to assist in making the device run smoothly when doing multiple tasks at once.
Please note that Desktops and Laptops have different physical RAM sizes. At the time this guide was written DDR3 and DDR4 RAM would be the suggested pieces of hardware to use with the computer for increased data rates.
你所需要的
工具
  1. Dell Inspiron 17-7746 RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Disconnect the Laptop from the AC adapter and turn off the Laptop.
  2. Dell Inspiron 17-7746 RAM Replacement: 步骤 2 中的图像 1,1
    • Place the laptop so the bottom faces up.
  3. Dell Inspiron 17-7746 RAM Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 17-7746 RAM Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 17-7746 RAM Replacement: 步骤 3 中的图像 3,3
    • Remove the silver 15mm PH 1 screw that holds the plastic cover in place over the battery.
    • Remove the silver 8mm screw that holds the plastic cover in place over the battery.
    • Keep these two screws together. Their size will matter when you reassemble.
  4. Dell Inspiron 17-7746 RAM Replacement: 步骤 4 中的图像 1,1
    • Using the metal jimmy, pry up to remove the first half of the cover.
  5. Dell Inspiron 17-7746 RAM Replacement: 步骤 5 中的图像 1,1
    • Apply pressure using your fingertips on the top of the cover and push toward the front of the laptop. This will make the plate slide off exposing the hard drive and battery.
  6. Dell Inspiron 17-7746 RAM Replacement: 步骤 6 中的图像 1,1
    • Using the metal jimmy, remove the cover plate, this will expose the RAM.
  7. Dell Inspiron 17-7746 RAM Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 17-7746 RAM Replacement: 步骤 7 中的图像 2,2
    • Apply outward pressure using fingers or a spudger on the small tabs on the RAM. Once freed the RAM will need to be lifted slightly, angling it upward, and then pulled out toward yourself.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 10
总计 320
