Dell Inspiron 16-7610 Wi-Fi Card Replacement
简介
转到步骤 1If you are dealing with issues like network stability or even network failure on your Dell Inspiron 16-7610 laptop, follow this guide to replace the Wi-Fi card in the laptop. A new network card should improve the Wi-Fi performance when compared to the older card.
Before beginning this repair, power off your laptop, unplug from the AC adapter, and unplug the battery from the motherboard.
Flip the device over, so the backside is facing up.
Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
Use a Phillips #00 screwdriver to remove the screw that secures the Wi-Fi card bracket to the system board.
Lift the Wi-Fi card bracket off of the Wi-Fi card.
