简介
Follow this guide to remove the back case of your Dell Inspiron 16 7610 to access the internals of your laptop or replace it if it has broken or cracked.
你所需要的
Flip the device over, so the backside is facing up.
Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
1指南评论
Followed instructions. No clips broken but still cannot close the back cover. There’s a small gab in between the mouse and the cover when I close it.
