Dell Inspiron 15R SE 7520 Memory Module Replacement
5 - 7 分钟
非常容易
社区贡献指南
简介
转到步骤 1In this guide, we will be showing you how to remove and replace the Memory Module.
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module connector.
Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
即将完成!
终点
