跳转到主内容
Dell Inspiron 15R SE 7520 Memory Module Replacement
Terrence15
Terrence15 另一个贡献者
最后更新于 November 24, 2019
5 - 7 分钟
非常容易
社区贡献指南
In this guide, we will be showing you how to remove and replace the Memory Module.
  1. Dell Inspiron 15R SE 7520 Memory Module Replacement, Popping up the Memory Module: 步骤 1 中的图像 1,2 Dell Inspiron 15R SE 7520 Memory Module Replacement, Popping up the Memory Module: 步骤 1 中的图像 2,2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Inspiron 15R SE 7520 Memory Module Replacement, Remove the Memory Module: 步骤 2 中的图像 1,1
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 15R SE 7520 Memory Module Replacement, Align the Notch: 步骤 3 中的图像 1,2 Dell Inspiron 15R SE 7520 Memory Module Replacement, Align the Notch: 步骤 3 中的图像 2,2
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  4. Dell Inspiron 15R SE 7520 Memory Module Replacement, Sliding the Memory Module: 步骤 4 中的图像 1,1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
终点
Terrence15
于12/18/17注册
79,555 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 241
