跳转到主内容
Dell Inspiron 15R SE 7520 Hard Drive Replacement
Terrence15
Terrence15 另一个贡献者
最后更新于 November 24, 2019
5 - 7 分钟
简单
社区贡献指南
In this guide, we will be showing you how to remove and replace the Hard Drive.
你所需要的
工具
  1. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Remove the Screws: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Sliding the Hard Drive: 步骤 2 中的图像 1,1
    • Using the pull-tab, slide the hard-drive assembly toward the back of the computer to disconnect the hard-drive assembly from the connector on the system board.
  3. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 步骤 3 中的图像 1,1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Lifting the Hard Drive: 步骤 5 中的图像 1,2 Dell Inspiron 15R SE 7520 Hard Drive Replacement, Lifting the Hard Drive: 步骤 5 中的图像 2,2
    • Lift the hard drive off the hard-drive bracket.
  6. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Align the Screw Holes: 步骤 6 中的图像 1,1
    • Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Replace the Screws: 步骤 7 中的图像 1,1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Place the Hard-Drive Assembly: 步骤 8 中的图像 1,1
    • Place the hard-drive assembly on the computer base.
  9. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Sliding the Hard Drive Assembly: 步骤 9 中的图像 1,1
    • Using the pull-tab, slide the hard-drive assembly toward the front of the computer, to connect the hard-drive assembly to the connector on the system board.
  10. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Replace the Screws: 步骤 10 中的图像 1,1
    • Replace the screws that secure the hard-drive assembly to the computer base.
终点
另外一个人完成了本指南。
Terrence15
于12/18/17注册
79,555 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 1,065
