跳转到主内容
Dell Inspiron 15-7567 RAM Replacement
James Bedortha
James Bedortha3 其他贡献者
最后更新于 December 31, 2018
5 - 8 分钟
简单
This is an easy component to replace and only need a screwdriver to complete. This may be replaced if you get a blue screen before the laptop starts.
你所需要的
工具
  1. Dell Inspiron 15-7567 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 RAM Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-7567 RAM Replacement: 步骤 2 中的图像 2,2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 RAM Replacement: 步骤 3 中的图像 1,1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 RAM Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-7567 RAM Replacement: 步骤 4 中的图像 2,2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 RAM Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 15-7567 RAM Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 RAM Replacement: 步骤 6 中的图像 1,1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 RAM Replacement, RAM: 步骤 7 中的图像 1,2 Dell Inspiron 15-7567 RAM Replacement, RAM: 步骤 7 中的图像 2,2
    • Remove the 3mm screw on the back using a Phillips #1 screwdriver.
  8. Dell Inspiron 15-7567 RAM Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 15-7567 RAM Replacement: 步骤 8 中的图像 2,2
    • Remove the panel by lifting up the side towards you
  9. Dell Inspiron 15-7567 RAM Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 15-7567 RAM Replacement: 步骤 9 中的图像 2,2
    • Release the two clips on the left and right side, by pushing outward on the side towards you.
    • The RAM strip will extend out. Pull towards you at a slight angle.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 30
总计 798
