跳转到主内容
Dell Inspiron 15-7559 Repair Memory Modules Replacement
Terrence15
Terrence152 其他贡献者
最后更新于 November 16, 2019
5 - 8 分钟
简单
社区贡献指南
In this guide, we will be showing you how to remove and replace the Memory Modules.
你所需要的
工具
  1. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Repair Memory Modules Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: 步骤 2 中的图像 3,3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Repair Memory Modules Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: 步骤 3 中的图像 3,3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Popping up the Memory Module: 步骤 4 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  5. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Sliding the Memory Module: 步骤 5 中的图像 1,1
    • Slide and remove the memory module from the memory-module slot.
  6. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Align the Notch: 步骤 6 中的图像 1,1
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  7. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Sliding the Memory Module: 步骤 7 中的图像 1,1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
终点
2等其他人完成本指南。
Terrence15
于12/18/17注册
79,549 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 16
总计 1,184
