跳转到主内容
Dell Inspiron 15-7548 Motherboard Replacement
Michael Nunez
Michael Nunez4 其他贡献者
最后更新于 December 29, 2022
没有估计
中等
动态照片拍摄
需要更好的图片
缺少细节
If your Dell Inspiron 15-7548 is operating slowly, it may be place to replace your motherboard.
Make sure your current software is up to date before deciding to replace your motherboard.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
你所需要的
工具
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-7548 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Remove the screws holding the battery.
  4. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery ribbon connector.
  5. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Disconnect the CPU fan ribbon.
  6. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Disconnect the display screen ribbon connector.
  7. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the blue ribbon connector.
  8. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Disconnect the blue and gold ribbon connectors.
  9. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Disconnect the speaker cable.
  10. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Disconnect the WiFi card connections.
  11. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the screws securing the heat sink.
  12. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the heat sink.
  13. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the motherboard screws.
  14. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove the motherboard.
结论
Michael Nunez
于04/12/22注册
325 声望
创作了2篇指南
团队
IUPUI, Team 3-3, Beck Spring 2022 IUPUI, Team 3-3, Beck Spring 2022 的会员
IUPUI-BECK-S22S3G3
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 16
总计 707
