跳转到主内容
Dell Inspiron 15-7548 Fan Replacement
Christopher Fisher
Christopher Fisher3 其他贡献者
最后更新于 May 7, 2024
15 - 20 分钟
中等
This guide will walk you through how to remove the Fan in your Dell Inspiron 15-7548.
你所需要的
工具
查看更多...
  1. Dell Inspiron 15-7548 Fan Replacement, Back Panel: 步骤 1 中的图像 1,2 Dell Inspiron 15-7548 Fan Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Fan Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-7548 Fan Replacement: 步骤 2 中的图像 2,2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Fan Replacement, Battery: 步骤 3 中的图像 1,2 Dell Inspiron 15-7548 Fan Replacement, Battery: 步骤 3 中的图像 2,2
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548 Fan Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-7548 Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
  5. Dell Inspiron 15-7548 Fan Replacement, Fan: 步骤 5 中的图像 1,1
    • The two fans are located at the top of the computer.
    • The fan on the left is for the GPU (Graphics processing unit) and the right fan is for the CPU (Central processing unit).
  6. Dell Inspiron 15-7548 Fan Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 15-7548 Fan Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 15-7548 Fan Replacement: 步骤 6 中的图像 3,3
    • To unplug the CPU fan lift the black plastic cutout next to the fan.
    • The connection can be removed by hand or with the plastic spudger.
  7. Dell Inspiron 15-7548 Fan Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 15-7548 Fan Replacement: 步骤 7 中的图像 2,2
    • Remove the two 2x3mm screws from the fan using the Phillips #1 screwdriver.
    • The unit may now be removed from the board.
    • The black cord running alongside the fan is for the display. Push it aside if it stops you from removing the fan.
  8. Dell Inspiron 15-7548 Fan Replacement: 步骤 8 中的图像 1,3 Dell Inspiron 15-7548 Fan Replacement: 步骤 8 中的图像 2,3 Dell Inspiron 15-7548 Fan Replacement: 步骤 8 中的图像 3,3
    • Disconnect the unit from the motherboard.
    • It may be easier to disconnect with the spudger tool but it can also be done by hand.
  9. Dell Inspiron 15-7548 Fan Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 15-7548 Fan Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • The black and white wires need to be unplugged and removed from the tabs on the fan.
    • Use a pair of tweezers to unplug the wires.
    • When reconnecting the wires connect the white to the top plug and the black to the bottom.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 34
总计 2,786
