跳转到主内容
Dell Inspiron 15-7537 RAM Replacement
Jean Whitmore
Jean Whitmore3 其他贡献者
最后更新于 June 16, 2015
10 - 15 分钟
中等
Use this guide to replace the RAM if you would like to upgrade the RAM, or replace it if there is damage.
你所需要的
工具
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Dell Inspiron 15-7537 RAM Replacement, Bottom Case: 步骤 1 中的图像 1,1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 RAM Replacement: 步骤 2 中的图像 1,1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 RAM Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 RAM Replacement, RAM: 步骤 4 中的图像 1,2 Dell Inspiron 15-7537 RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Gently pull apart clips on the ends of the memory module until the memory module pops up.
  5. Dell Inspiron 15-7537 RAM Replacement: 步骤 5 中的图像 1,1
    • Pull the RAM out at a 45 degree angle.
结论
2等其他人完成本指南。
Jean Whitmore
于01/22/15注册
984 声望
创作了7篇指南
团队
Cal Poly, Team 18-2, Maness Winter 2015 Cal Poly, Team 18-2, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 2,473
