跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 15-7537 Keyboard Replacement
你所需要的
    1. Dell Inspiron 15-7537 Keyboard Replacement, Bottom Case: 步骤 1 中的图像 1,1
      • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
      • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
      • These screws will stay captive to the case.
      询问修复机器人
      添加评论
    2. Dell Inspiron 15-7537 Keyboard Replacement: 步骤 2 中的图像 1,1
      • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
      询问修复机器人
      添加评论
    3. Dell Inspiron 15-7537 Keyboard Replacement: 步骤 3 中的图像 1,1
      • Use a spudger to remove the base cover from the rest of bottom cover.
      添加评论
    1. Dell Inspiron 15-7537 Keyboard Replacement, Battery: 步骤 4 中的图像 1,1
      • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
      询问修复机器人
      添加评论
    2. Dell Inspiron 15-7537 Keyboard Replacement: 步骤 5 中的图像 1,1
      • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
      • Using the pull tab on the battery, lift the battery out of the computer.
      添加评论
    1. Dell Inspiron 15-7537 Keyboard Replacement, Removing the Keyboard: 步骤 6 中的图像 1,1
      • Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
      询问修复机器人
      添加评论
    2. Dell Inspiron 15-7537 Keyboard Replacement: 步骤 7 中的图像 1,1
      • Flip over the computer and open the display as far as it can go.
      • Use the spudger to remove the keyboard from the palm assembly.
      询问修复机器人
      添加评论
    3. Dell Inspiron 15-7537 Keyboard Replacement: 步骤 8 中的图像 1,1
      • Gently flip over the keyboard and place it on the palm rest assembly.
      • Lift the connector latches and disconnect the keyboard and the keyboard back-light cables.
      询问修复机器人
      添加评论
    4. Dell Inspiron 15-7537 Keyboard Replacement: 步骤 9 中的图像 1,3 Dell Inspiron 15-7537 Keyboard Replacement: 步骤 9 中的图像 2,3 Dell Inspiron 15-7537 Keyboard Replacement: 步骤 9 中的图像 3,3
      • Take the keyboard off the palm rest assembly.
      添加评论
结论
取消:我没有完成这个指南。
11等其他人完成本指南。
团队
Cal Poly, Team 18-2, Maness Winter 2015 Cal Poly, Team 18-2, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G2
4 名成员
创作了96篇指南
3指南评论
Great guide, thanks for the help!
Patrick S - 回复 分享
Thanks It’s Useful
ahmed omar - 回复 分享
It is important to note that the little black clips on the ends of the keyboard wires SWIVEL UP! I broke mine because nothing in this guide told me how to get the wires out properly.
benton.addison - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 32
总计 7,239
