跳转到主内容
Dell Inspiron 15-5567 Speakers Replacement
Sattam Bakolka
Sattam Bakolka3 其他贡献者
最后更新于 April 27, 2020
5 - 10 分钟
中等
社区贡献指南
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
Laptop speakers are usually very susceptible to damage because they’re sensitive to water and any other small particles that manage to get inside it. This guide will help you replace the speakers of the Dell Inspiron 15-5567. It is a relatively easy replacement. You'll need to take the back cover first as a prerequisite, and the two speakers are located on the top right and left. Please be careful not to press hard on the speaker cones as it’s susceptible to damage and rupture.
你所需要的
工具
  1. Dell Inspiron 15-5567 Speakers Replacement, Back Cover: 步骤 1 中的图像 1,3 Dell Inspiron 15-5567 Speakers Replacement, Back Cover: 步骤 1 中的图像 2,3 Dell Inspiron 15-5567 Speakers Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 Speakers Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-5567 Speakers Replacement: 步骤 2 中的图像 2,2
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 Speakers Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 15-5567 Speakers Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 15-5567 Speakers Replacement: 步骤 3 中的图像 3,3
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
  4. Dell Inspiron 15-5567 Speakers Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screws that secure the battery bracket to the system board and palm rest and keyboard assembly.
  5. Dell Inspiron 15-5567 Speakers Replacement, Removing the Battery Bracket: 步骤 5 中的图像 1,1
    • Lift and remove the battery bracket.
  6. Dell Inspiron 15-5567 Speakers Replacement, Remove the Screw: 步骤 6 中的图像 1,1
    • Remove the screw that secures the battery to the palm rest and keyboard assembly.
    • Note the location of the screw that secures the battery to the palm rest and keyboard assembly.
  7. Dell Inspiron 15-5567 Speakers Replacement, Lifting the Battery: 步骤 7 中的图像 1,1
    • Lift the battery off the palm rest and keyboard assembly.
  8. Dell Inspiron 15-5567 Speakers Replacement, Speakers: 步骤 8 中的图像 1,3 Dell Inspiron 15-5567 Speakers Replacement, Speakers: 步骤 8 中的图像 2,3 Dell Inspiron 15-5567 Speakers Replacement, Speakers: 步骤 8 中的图像 3,3
    • Remove the cable by using the blue plastic opening tool.
    • Lift the first speaker gently and remove it.
  9. Dell Inspiron 15-5567 Speakers Replacement: 步骤 9 中的图像 1,1
    • Lift the other speaker gently and remove it.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 28
总计 1,053
