跳转到主内容
Dell Inspiron 15-5565 Battery Replacement
Avery Wasylyszyn
Avery Wasylyszyn4 其他贡献者
最后更新于 May 31, 2023
15分钟
非常容易
In this guide, you will successfully learn how to replace the battery in a Dell Inspiron 15-5565. Please see this page to perform troubleshooting.
Swollen batteries need to be replaced and should not be used. Visit this page for information on how to dispose of a swollen battery.
If the battery is stuck due to swelling, do not try to remove the battery yourself and seek professional assistance. For this device you can contact Dell Technical support to assist in this matter.
你所需要的
工具
  1. Dell Inspiron 15-5565 Battery Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Battery Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 15-5565 Battery Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 15-5565 Battery Replacement: 步骤 2 中的图像 3,3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Battery Replacement, Back Cover: 步骤 3 中的图像 1,2 Dell Inspiron 15-5565 Battery Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-5565 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Battery Replacement, Battery: 步骤 5 中的图像 1,2 Dell Inspiron 15-5565 Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the three 5 mm screws from the battery bracket using a Phillips #00 screwdriver.
  6. Dell Inspiron 15-5565 Battery Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 15-5565 Battery Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 15-5565 Battery Replacement: 步骤 6 中的图像 3,3
    • Remove the five 5 mm screws from the outer edges of the battery using a Phillips #00 screwdriver.
    • Remove the battery from the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 34
总计 454
