跳转到主内容
Dell Inspiron 15-5559 Keyboard Replacement
你所需要的
  1. Dell Inspiron 15-5559 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 Dell Inspiron 15-5559 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 Dell Inspiron 15-5559 Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Use the metal spudger to pry the keyboard off. Do this by inserting the spudger into each of the five indicated slots at the top of the keyboard and gently pulling up on the keyboard with the spudger. Do not be afraid to use a bit of muscle to remove the keyboard, as it takes a bit of force to remove
  2. Dell Inspiron 15-5559 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Once you have pried the keyboard off with the spudger, lift the keyboard upward with you hands.
    • It is important to note that the keyboard is still attached to the device with two flat connective cables. It is important that you gently remove the keyboard to prevent damaging the cables.
  3. Dell Inspiron 15-5559 Keyboard Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15-5559 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Once the keyboard has been lifted you will notice two conductive tape cables. one large and one small.
  4. Dell Inspiron 15-5559 Keyboard Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-5559 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Disconnect the smaller of the two flat conductive tape cables.
    • Place a metal spudger on the end of the cable that is connected to the laptop and use it to lift the black clasp holding the tape down, then pull the cable out toward the right. Repeat for the second larger piece of conductive tape.
    • You should remove this flat connective cable with care to prevent damaging it.
结论
4等其他人完成本指南。
Martin Lechuga
于03/18/18注册
183 声望
撰写一个指南
团队
Baylor, Team S5-G5, Williams Spring 2018 Baylor, Team S5-G5, Williams Spring 2018 的会员
BU-WILLIAMS-S18S5G5
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 22
总计 3,154
